Date/Time: Sat, 04 May 2024 21:24:33 +0000
Plot Daily OHLC on DOM
View Count: 886
[2020-04-04 16:01:20] |
User600014 - Posts: 12 |
I have a chartbook where I place yesterdays Open, High, Low and Close on my DOM as shown in the attachment. I did this sometime ago and forgot how. I am building a new DOM and would like to place this in a similar fashion on the new DOM but I am limited to a small set of indicators on the DOM that I can add. How is this done? Thanks
Daily OHLC.png / V - Attached On 2020-04-04 15:57:47 UTC - Size: 120.07 KB - 308 views Attachment Deleted. |
[2020-04-06 05:54:35] |
ticinotrader - Posts: 378 |
You can always directly ask the creator of the original chartbook (TicinoTrader ZN Playbook) to provide the instructions or make adjustments to the DOM, chartbook. Simply you can add the OHLC study to an existing chart, and overlay the study values on the DOM using the Study/Price overlay study available on the DOM. Alternatively you can set the OHLC study to display the levels labels in the 'Label column' then turn on the label column on the DOM. Hope this helps. Regards, tt |
[2020-04-06 11:10:24] |
Refer to the instructions here for this: Chart Trading and the Chart DOM: Adding Studies on a Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
