Date/Time: Sun, 19 May 2024 03:15:37 +0000
"true" command
View Count: 506
[2020-04-04 12:07:58] |
User875891 - Posts: 63 |
what would be the "true" command when programming from studies i see the option is available on spread sheets but cant find docs on studies |
[2020-04-04 12:18:46] |
fixed
[2020-04-05 22:25:41] |
You can use 1, true, or TRUE.
