Date/Time: Sun, 19 May 2024 03:16:29 +0000
[Programming Help] - Building problems
View Count: 684
[2020-04-03 19:30:14] |
User837393 - Posts: 132 |
Hello, I'm trying to build the following code (sourced @ Source code for ADXVMA), but the SC builder is sending me te following error. Can you assist ? Best regards, Errors : - Starting remote build of Custom Studies Source files: ADXVMA.h. 64-bit -- 15:26:28 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: No result text was given. -- End of Build -- 15:26:28 #include "sierrachart.h" #define ADXVMA sc.Subgraph[0] #define DI_Sum sc.Subgraph[3] #define ma sc.Subgraph[4] #define pdm sc.Subgraph[5] #define mdm sc.Subgraph[6] #define pdi sc.Subgraph[7] #define mdi sc.Subgraph[8] #define HHV sc.Subgraph[12] #define LLV sc.Subgraph[13] #define out sc.Subgraph[14] #define FALSE 0 #define TRUE 1 #define LONG 1 #define SHORT -1 #define GREEN RGB(0,255,0) #define DKGREEN RGB(0,128,0) #define YELLOW RGB(255,255,0) #define LTYELLOW RGB(255,255,128) #define RED RGB(255,0,0) #define DKRED RGB(198,0,0) #define BLACK RGB(0,0,1) #define WHITE RGB(255,255,255) #define CYAN RGB(0,255,255) #define PURPLE RGB(255,0,255) #define GREY RGB(192,192,192) #define BLUE RGB(0,128,255) #define ORANGE RGB(255, 127, 0) //SCDLLName("ADXVMA") SCSFExport scsf_ADXVMA(SCStudyGraphRef sc) { if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "ADXVMA"; sc.StudyDescription = "ADXVMA"; sc.FreeDLL = 0; sc.AutoLoop = 1; // true sc.GraphRegion = 0; // Set the name of the first subgraph sc.Subgraph[0].Name = "ADXVMA"; sc.Subgraph[0].PrimaryColor = RED ; sc.Subgraph[0].DrawStyle = DRAWSTYLE_POINT ; sc.Subgraph[0].LineWidth = 2 ; sc.Input[0].Name = "Input Data"; sc.Input[0].SetInputDataIndex(SC_LAST); sc.Input[1].Name = "Length"; sc.Input[1].SetInt(14); sc.Input[2].Name = "RisingColor"; sc.Input[2].SetColor(BLUE); sc.Input[3].Name = "FlatColor"; sc.Input[3].SetColor(YELLOW); sc.Input[4].Name = "FallingColor"; sc.Input[4].SetColor(RED); return; } int i ; SCFloatArrayRef Price = sc.BaseDataIn[sc.Input[0].GetInputDataIndex()]; int len = sc.Input[1].GetInt(); sc.DataStartIndex = len; i = sc.CurrentIndex; ma[i] = Price[i]; if (Price[i] > Price[i-1]) { pdm[i] = Price[i] - Price[i-1]; mdm[i] = mdm[i-1]; } else if (Price[i] < Price[i-1]) { mdm[i] = Price[i-1] - Price[i]; //This array is not displayed. pdm[i] = pdm[i-1]; } else { mdm[i] = 0.0f; pdm[i] = pdm[i-1]; } pdm[i] = ((len - 1) * pdm[i-1] + pdm[i]) / len; //ema. mdm[i] = ((len - 1) * mdm[i-1] + mdm[i]) / len; //ema. float TR = pdm[i] + mdm[i]; if (TR > 0) { pdi[i] =pdm[i] / TR; mdi[i] = mdm[i] / TR; } else { pdi[i] = 0; mdi[i] = 0; } pdi[i] = ((len - 1) * pdi[i-1] + pdi[i]) / len; //ema. mdi[i] = ((len - 1) * mdi[i-1] + mdi[i]) / len; //ema. double DI_Diff = pdi[i] - mdi[i]; if (DI_Diff < 0) DI_Diff = -DI_Diff; //Only positive momentum signals are used. DI_Sum[i] = pdi[i] + mdi[i]; double DI_Factor = 0; //Zero case, DI_Diff will also be zero when DI_Sum i s zero. if (DI_Sum[i] > 0) out[i] = (float) DI_Diff / DI_Sum[i]; else out[i]= 0; out[i] = ((len - 1) * out[i-1] + out[i]) / len; if (out[i] > out[i-1]) { HHV[i] = out[i]; LLV[i] = out[i-1]; } else { HHV[i] = out[i-1]; LLV[i] = out[i]; } for (int j = 1; j < len; j++) { if (out[i-j-1] > HHV[i]) HHV[i] = out[i-j-1]; if (out[i-j-1] < LLV[i]) LLV[i] = out[i-j-1]; } double diff = HHV[i] - LLV[i]; double VI = 0; if (diff > 0) VI = (out[i] - LLV[i]) / diff; ma[i] = (float) ((len - VI) * ma[i-1] + VI * Price[i]) / len; //Chande VMA formula with ema built in. ADXVMA[i] = ma[i]; if (ADXVMA[i] > ADXVMA[i-1]) sc.Subgraph[0].DataColor[i] = sc.Input[2].GetColor(); else if (ADXVMA[i] < ADXVMA[i-1]) sc.Subgraph[0].DataColor[i] = sc.Input[4].GetColor(); else if (ADXVMA[i] == ADXVMA[i-1]) sc.Subgraph[0].DataColor[i] = sc.Input[3].GetColor(); } Date Time Of Last Edit: 2020-04-03 19:32:05
[2020-04-05 00:07:33] |
Ackin - Posts: 1865 |
//SCDLLName("ADXVMA") ... Why // ? SCDLLName should be there if this is the only study in the library sc.FreeDLL = 0; .... remove this line and try recompile again |
[2020-04-05 15:12:32] |
User907968 - Posts: 804 |
In addition you can try renaming your file from 'ADXVMA.h' to 'ADXVMA.cpp'
