Date/Time: Sun, 05 May 2024 10:20:25 +0000
Denali Feed - How to get Real Time $SPX and SPY
View Count: 1638
[2020-04-03 18:55:50] |
User832512 - Posts: 22 |
I switched over to the SC Denali feed and can get historical $SPX - SPY, but how do I enable these symbols for "real time"?
[2020-04-03 20:32:13] |
One of those is a cash index another one is an ETF. For real-time data for these you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-29 12:48:56] |
Is there any consideration for the Denali feed to enable the SPX, NDX indexes or SPY, QQQ ETF's?
[2020-06-29 18:47:45] |
Yes this is all fully supported through the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Also be aware of the discount you will get being you have the Denali Exchange Data Feed as well: Sierra Chart Exchange Data Feed: Data Feed Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-29 18:48:11
