Date/Time: Sun, 19 May 2024 06:58:54 +0000
Stellar
View Count: 579
[2020-04-03 12:02:11] |
User858758 - Posts: 14 |
We are no longer using TT for trading and have moved to Stellar, do you support this trading software? If not and we signup for the Denail package will we still be charged the exchange fees even though we are already paying them?
[2020-04-03 12:26:43] |
No we do not support that. You can avoid paying the professional fees a second time if you use "netting" through the CME. However, you have to ask the CME if you can take advantage of that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-03 12:27:17
[2020-04-03 12:31:29] |
How do I do the netting, are they any instructions?
[2020-04-04 09:58:17] |
You first need to contact the CME to see if they can offer this for you. That is the very first step.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-04 09:58:31
