Date/Time: Sat, 18 May 2024 06:22:48 +0000
maximum for the volume per bar type period
View Count: 837
[2020-04-02 09:31:31] |
User719206 - Posts: 92 |
Hello , actually the maximum volume for the volume per period looks to be 2 147 483 647 e for xpt usd on bitmex , is there a way to get more than that ? Thanks :)
[2020-04-02 19:37:51] |
There should be support for higher values than that. Post an image of the chart with that Volume study following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-03 07:38:53] |
I Dont speak about a volume study but when i use volume per bar as a bar periode type, if for example i want to use the setting 100 billions , i gonna get a 2 147 483 647 volume per bar .
[2020-04-03 09:35:14] |
Ackin - Posts: 1865 |
Reason why: This is due to the size of the data type inside the code. You would have to have a function to divide the continuous volume there. For example divided by 10000 |
[2020-04-03 10:34:47] |
verry smart ! thank a lot for your help
[2020-04-03 10:55:49] |
Yes you would want to reduce the volume in the chart with a multiplier: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-07 21:29:59] |
Unfortunatly it didn t help me, my target is to get get volume per bar ( as bar period ) bigger than 2 147 482 647 but when i change the volume multiplier i just get smaller bar period ( when i choice 0.1 and 10 as volume multiplier same result, smaller bar) the setting for the volume per bar seems locked at 2 147 482 647.
[2020-04-07 23:05:56] |
Update to the latest release. We made a change which should resolve this. Instructions: Software Download: Fast Update We were not able to go to a 64-bit value, that is much more involved, but we used an unsigned 32-bit integer for the volume per bar setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-07 23:06:10
[2020-04-08 12:49:43] |
I did it, but no change unfrtunatly .
[2020-04-13 10:00:00] |
do you have some news about the problem ?
[2020-04-13 10:42:03] |
We cannot commit any further time to this now.
