Date/Time: Wed, 30 Sep 2026 08:21:16 +0000
copy study drawings from 1min chart to numbers bars chart
View Count: 916
| [2020-04-02 08:42:04] |
| User363388 - Posts: 5 |
Hey, i´m using a custom study (1 min chart) which draws extended lines from the middle of every IB/OB to the price axis. Is it possible to copy these "study drawings" to a numbers bar chart (range chart) because i dont wanna draw every line manually and copy then via chart settings-->advanced settings2-->copy chart drawings from chart. Is there a study like price overlay study (which is not working with numbers bars) which makes this possible? Thanks in advance. |
| [2020-04-02 09:43:04] |
Are those lines implemented as Subgraphs or Chart Drawings?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-02 09:43:11
| [2020-04-13 13:03:56] |
They are implemented as Subgraphs with draw style, line style etc.
| [2020-04-13 19:17:32] |
Then you can use the Study/Price Overlay study to get these onto the Numbers Bars chart by specifying your study and the subgraph that has the drawing. You would need multiple copies of the Study/Price Overlay for each subgraph you want to copy. Refer to the information here: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
