Date/Time: Mon, 29 Apr 2024 06:58:59 +0000
Global PNL Management / Wrong daily PNL
View Count: 1067
[2020-03-31 22:58:02] |
nosast - Posts: 290 |
It seems like Global Profit and Loss shows 1/10th of the real loss!! I was trading ES, not MES and the Trade Log got my loss right, why is Global PNL different?
Date Time Of Last Edit: 2020-03-31 23:25:55
[2020-04-01 20:11:03] |
Updated to 2074 and did some SIM losses. Still the PNL for Global PNL management shows only 1/10th of the real loss. Looks like GlobalPNL-Mgmt. thinks I was trading MES instead of ES. How come these could differ? Is there anything to change this? I already resetted and re-activated GPNL-Mgmt without any diffence. see attached |
SNAG_ 2020-04-01 - 22.08.21.png / V - Attached On 2020-04-01 20:10:58 UTC - Size: 67.39 KB - 325 views |
[2020-04-02 10:56:33] |
We apologize for the delay with this. We need a little more time to look this over. But check the Currency Value Per Tick in the charts in the Chart Settings used for trading.
[2020-04-02 12:00:56] |
Curreny value per tick is correct. I checked this already. If I would change it here - the Trade Activity Log would also show wrong numbers.
SNAG_ 2020-04-02 - 13.59.04.png / V - Attached On 2020-04-02 12:00:50 UTC - Size: 16.48 KB - 265 views |
[2020-04-03 11:18:36] |
You need to check that value in the Chart >> Chart Settings for the particular chart that has a wrong profit/loss value. Refer to: Profit/Loss Calculations and Symbol Settings You can see all of the charts calculating a Trades list in the list here: Trade Activity Log: Trade Statistics for Charts (Chart Stats) Tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-03 11:19:28
[2020-04-03 11:28:36] |
It's fine in the trades list. Only in Global PNL Management the numbers are wrong.
[2020-04-03 11:42:48] |
We need to understand this better. We need a full screenshot of the Trade Stats for Charts tab of the Trade Activity Log showing all of the Daily Net PL values. And we need a screenshot of the profit/loss value you are referring to in the Global Profit/Loss Management window. There simply cannot be any discrepancy between the two. You can privately attach them here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-04 11:32:07
[2020-04-03 12:04:37] |
Attachement in post number 2 is not sufficient?
[2020-04-04 11:31:33] |
You are making a completely wrong comparison here: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=37408 The Global Profit/Loss Management does not use the data from the Account Stats tab at all. That is completely irrelevant and has no connection at all. You need to look at the Trade Stats for Charts tab as we requested. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-04 11:32:29
[2020-04-04 11:47:07] |
Refer to the documentation here: Global Profit/Loss Management: How Daily Net Profit/Loss is Calculated for a Trade Account All of this has been very well documented for a long time now. Everything is there. Keep in mind, our time is very limited and this takes away time from our development when we are spending time on unnecessary support requests. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-04 11:47:17
[2020-07-01 11:54:27] |
This is still not working for me. I want to quote ES but trade MES. All works fine but the PNL in charts trade tab and Global PNL management is wrong and based on ES instead of MES. See attached where a 1 tick profit with 1 MES contract results in 12.50 USD currency value.
SNAG_ 2020-07-01 - 13-51-48.png / V - Attached On 2020-07-01 11:54:23 UTC - Size: 164.7 KB - 228 views |
[2020-07-01 19:05:55] |
Refer to this setting: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
