Date/Time: Thu, 02 May 2024 20:01:05 +0000
current day's range midpoint
View Count: 3012
[2013-04-15 03:36:23] |
iafayte - Posts: 11 |
Is there an indicator or combination of indicators I can use to display the current evolving trading day's midpoint as a line?
[2013-04-15 06:53:57] |
Use the following 2 studies: Daily OHLC Study Subgraphs Average Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-22 01:48:38] |
User409644 - Posts: 39 |
How do you use the Study subgraphs to the daily OHLC ? How do you set it up? |
[2024-01-22 02:26:18] |
cmet - Posts: 537 |
You can also just use something like the Initial Balance study. Use Daily IB type. Set the RTH start/end times for your time zone. Intraday Number of Minutes: 405 mins (for ES Futures, 390 for stocks) Start End Time Method: Use Start/End Time IB High will now be high of session, IB Mid will be the mid, IB Low, the low. These will change during the session based on price movement. On the Subgraph you can turn on/off the levels you don't need. Friday's ES RTH in the attached image. Date Time Of Last Edit: 2024-01-22 02:28:04
ES 1-19.jpg / V - Attached On 2024-01-22 02:27:48 UTC - Size: 48.12 KB - 40 views |
