Date/Time: Sat, 27 Apr 2024 07:43:11 +0000
Bitcoin Historical Data
View Count: 670
[2020-03-31 10:21:49] |
User723592 - Posts: 9 |
Hi, is it possible to get intraday data for Bitcoin further back, than 6mons... maybe 5 years or so? cheers horst jr. |
[2020-03-31 17:38:51] |
Yes this is available. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-31 17:39:03
[2021-05-11 18:53:08] |
User45989 - Posts: 54 |
Which symbol is used for BTC data for 5 years or so?
[2021-05-11 20:21:52] |
Use this symbol: XBTUSD-BMEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-28 15:54:24] |
Can you confirm which time zone is being used for the timestamps for this symbol? Is it Seychelles (GMT+4)?
[2021-05-28 15:58:18] |
Sierra_Chart Engineering - Posts: 14107 |
You can control the time zone. Refer to: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-28 22:39:51] |
I am concerned that about any effect that DST would have on the datetime stamps of the data. I am assuming that because Seychelles where the BitMEX exchange is located has no DST that this is a non-issue? |
[2021-05-29 06:34:47] |
BitMex is not in Seychelles. That is just a place of incorporation. The BitMex systems are in Europe last time we checked. All data received from BitMex is time stamped according to UTC and can be can converted to any time zone accurately. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
