Date/Time: Tue, 15 Jul 2025 19:27:48 +0000
Error when trying to trade Service Order ID None?
View Count: 1915
[2014-01-11 12:47:27]
slipperfoot - Posts: 11
I dont know why, i configured mtgox and created an api key with the correct privileges for sierrachart. After configuring sierrachart everything seems smooth, i enable trading, turn off simulated trading, put in a buy limit order and get the following error. First time using the Trading DOM. Thought i did everything correctly but guess i didnt. Just a small hurdle i presume. Any help is appreciated guys.
Im getting the error
Trade Order Error - MtGox order update (Rejected) - Chosen API not found. Internal Order ID: 5. Service Order ID: (none). Symbol: BTCusd
Edit, if this is a Mt Gox issue, is it possible to explore a macro type of alternative or will that be to sloppy?
Date Time Of Last Edit: 2014-01-11 19:49:31
[2014-01-11 23:35:26]
Could you confirm if you have set the API Key and API Secret in File >> Data/Trade Service Settings window?
Could you also let us know what the Order Quantity was? Currently 1.0000 BTC is specified as 10000 in Sierra Chart.
Date Time Of Last Edit: 2014-01-12 08:19:25
[2014-01-11 23:36:29]
What we are planning to do is add support for:
https://www.bitfinex.com/pages/api
We have contacted them, but they are not particularly communicative with us.
We want to develop quality interface to that particular exchange. Not something substandard.
Date Time Of Last Edit: 2014-01-11 23:36:51
[2014-01-12 03:54:15]
Yes Api Key and secret key are plugged in, also the proper privileges have been set for the api. I specified order quantity to '1' instead of the '10000' or '1.0000'. Should it be working ATM? Or is it really a Mt Gox issue??
I am familiar with bitfinex and am quite fond of their platform, more so then any other exchange. I respect Bitfinex for being one of the more versatile exchanges. But my second question would be; When and if sierra stops supporting Mtgox trading, will you guys still support the data feed for mt gox?
Thanks SC Pros!
Date Time Of Last Edit: 2014-01-12 03:57:29
[2014-01-12 08:21:13]
A quantity of 1 is going to get rejected from MTGox. It is too small. This error:
Chosen API not found. comes from MTGox.
We will continue to support the MTGox data feed. And as we understand you can trade MTGox through Bitfinex . Contact them and let them know that you would like to see Sierra Chart work with their exchange.
Date Time Of Last Edit: 2014-01-12 08:21:29
