Date/Time: Thu, 02 May 2024 12:51:03 +0000
Is it possible for a SC auto bot to trade for you without having the program open on pc?
View Count: 538
[2020-03-27 16:37:18] |
youngdolph - Posts: 2 |
Hi, Setup an automated bot. Is it possible to have this run without the Sierra Chart program being launched/open on my computer? For example, while I slept and computer was shut off. Or if I want the bot to run while I sleep, I'll need to make sure the program is open and my computer is active? Thank you. |
[2020-03-27 17:44:43] |
It is necessary for the Sierra Chart software to be running and connected to the trading server in order to have any auto-trading associated with the program occur. If the program is not running, then it is not possible for it to make a trade.
