Date/Time: Mon, 29 Apr 2024 11:00:45 +0000
IQFeed OHLC bars (750 number trades per bar) not matching Denali OHLC bars
View Count: 788
[2020-03-27 16:32:54] |
IconBob - Posts: 61 |
I use a website that has SC ES OHLC charts 750 number of trades per bar, created using IQFeed and Transact. The charts I created use the Denali Exchange Data Feed. The bars on the charts don’t match. Highs, lows, opens and closes are many times way off. I confirmed we have the same chart settings. The problem is trades are queued off of his chart bars. I'm hoping you have some thoughts on what the problem is. Is there something I'm overlooking? |
[2020-03-27 17:34:32] |
Usually this is caused by either different Session Times or by the option for New Bar at Session Start. Refer to the information here: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
