Date/Time: Thu, 02 May 2024 07:08:00 +0000
SCH unable to connect to IB TWS for data feed
View Count: 497
[2020-03-27 16:17:04] |
User599645 - Posts: 1 |
Hello, i have set SCH as instructed in tutorial. Anyway SCH is not downloading real time data from TWS. In attachment you can see screenshots that everything is set up properly. You can also check the message log which might ring a bell what the problem is. Thank you Date Time Of Last Edit: 2020-03-27 17:35:31
Private File Private File Private File |
[2020-03-27 17:36:43] |
There is a connection problem. In this case follow the steps here at step 27: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#IBResolvingConnectionIssue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-27 17:37:00
