Date/Time: Sat, 27 Apr 2024 16:57:56 +0000
Bar Chart Setting problem
View Count: 473
[2020-03-27 15:30:51] |
User595224 - Posts: 5 |
Dear Support team, I use the data feed from HKFE. I would like to have a bar chart with specific period for each bar. Can I do that in sierra chart. For example. The trading period of HKFE are 9:15-12:00 , 13:00-16:30 and 17:15-03:00. Can i set and show these 3 bars only per day? Can Sierra chart do this? Regards, Patrick |
[2020-03-27 15:59:48] |
Dear Support team I cannot access the link. Grateful if you would send to me again. Thanks. Regards, Patrick |
[2020-03-29 02:33:24] |
No this is not supported. It is only possible to have a fixed time period per chart bar or variable like based upon a Number of Trades or Volume.
