Date/Time: Sun, 05 May 2024 20:10:46 +0000
Separated symbols between left and right axis on the same chart region?
View Count: 558
[2020-03-26 23:49:00] |
SKZ90 - Posts: 74 |
Is there a way to have the "add additional symbol" study use the left axis and the main symbol use the right axis on the same chart region?
[2020-03-27 10:15:42] |
Yes you just need to enable the Left Side Scale: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
