Date/Time: Sun, 04 Oct 2026 17:40:40 +0000
How to configure Sierra when another login to data
View Count: 965
| [2020-03-26 16:22:08] |
| Sting111 - Posts: 2 |
I share my CQG data between Sierra and a Mobile app. I want Sierra to disconnect if I login from my mobile instead of disconnecting my mobile app. Sometimes I forget and leave the house. How do I do that.
| [2020-03-27 07:19:57] |
Once you login to the CQG Web application, Sierra Chart will be disconnected. You should really though look at the Sierra Chart order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service The web-based trading panel and Sierra Chart can be both connected to the trading server at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
