Date/Time: Fri, 03 May 2024 21:57:22 +0000
REMOVE DOTTED BOX PLEASE!?
View Count: 516
[2020-03-25 16:07:56] |
sjbenn85 - Posts: 11 |
Dear Sir/Madam, Please could you tell me how to show all of my chart? This dotted box is cutting off the bottom (at least i think this is what the problem is?). Your help would be much appreciated, best regards https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=37195 |
[2020-03-25 19:39:10] |
The dotted box is just showing the region for the Volume by Price graph. It is not the reason for the chart going below the bottom of the screen. First thing is to just Reset the scaling on the chart. Refer to the following for how to do this: Chart Scale and Scale Adjusting: Resetting the Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-26 11:18:47] |
I have reset my scales as instructed and nothing has changed; the dotted box is still showing!? Regards Simon |
[2020-03-26 18:39:32] |
There is an option to control this in the Volume by Price settings: Volume By Price Study: Draw Profile Outline Enclosing Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-26 18:39:42
