Date/Time: Fri, 03 May 2024 04:49:07 +0000
Function Key Shortcuts Disappeared After Upgrading to 2068
View Count: 450
[2020-03-25 04:36:30] |
User94606 - Posts: 327 |
The function keys shortcuts in the primary instance have completely disappeared after the upgrade to version 2068. However, the function keys in the sub-instance are still visible. How do I restore the function keys in my primary instance?
[2020-03-25 07:52:51] |
We do not know what you are referring to.
[2020-03-25 11:40:09] |
If you go under File tab or Chart tab in the primary instance, all the shortcuts such as Ctrl-B (open chartbook) under File tab or F5 (open chart) under Chart tab have all disappeared from the main/primary instance. In the sub-instance, these shortcuts (F5, Ctrl-B) are still visible under their respective File and Chart tabs
[2020-03-26 09:44:22] |
You can reset the keyboard shortcuts back to default. They must have been manually cleared previously. Refer to: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
