Date/Time: Mon, 29 Apr 2024 10:56:57 +0000
How DO I swith from Daily CHart to Weekly aand Monthly?
View Count: 754
[2020-03-24 23:59:54] |
User743183 - Posts: 1 |
I am a long time Sierra Chart user How DO I switch from Daily Chart to Weekly and Monthly? It used to be CTRL 8,9,0 Craig [information removed for privacy] Date Time Of Last Edit: 2020-03-25 14:42:50
[2020-03-25 02:31:58] |
User75002 - Posts: 117 |
Those works for me. Try confirming they are still set that way in Global Settings | Customize Keyboard Shortcuts. Select Chart | Bar Periods inside the customize keyboard shortcuts window.
Date Time Of Last Edit: 2020-03-25 02:33:07
[2020-03-26 02:36:18] |
Refer to the information here for the various ways to change the Bar Period: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
