Date/Time: Mon, 06 May 2024 11:02:06 +0000
Yes, another data question
View Count: 451
[2020-03-24 09:27:42] |
User876097 - Posts: 14 |
Hi Guys, I rarely if ever contact support but since I use SC combined with another platform, I am looking to be able to subscribe to one data provider for both platforms. Unfortunately Denali can't be used outside of SC. I have heard that Interactive Brokers has updated their API and that the tick data is now sufficient for Numbers bars printing. Do you still not recommend using it? Thank you in advance |
[2020-03-24 12:09:31] |
I have heard that Interactive Brokers has updated their API and that the tick data is now sufficient for Numbers bars printing. Do you still not recommend using it? Yes we would never recommend using their data for Numbers Bars. You must use the Sierra Chart provided data feeds instead.Unfortunately Denali can't be used outside of SC. It can be used by other programs on the same system. Refer to:Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-24 12:10:18
