Date/Time: Fri, 03 May 2024 13:49:22 +0000
connect interactive brokers
View Count: 717
[2020-03-24 04:17:32] |
User792578 - Posts: 9 |
Hi, i read almost all Documentation but i couldnt find accurate answer. Suppose i want to execute futures in IB account depends on indicator on sieera charts. for example: i want to define that if RSI is above 50 (at sierra charts studies) than buy or sell future contract automatically on IB. (only for example). If the answer is yes my 2nd question is: whice language can i do it ( PYTHON ,C++ , JAVA). Thanks in advance and sorry if the answer is already been posted here. i read almost everything and i didnt find. amit |
[2020-03-24 12:04:43] |
This is supported. For something simple like this we recommend using this study: Trading System Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-24 14:48:43] |
Hi, Thanks for your answer but the Execution of trade (future contract) has to be in interactive brokers. how can i connect interactive brokers and sierra charts? |
[2020-03-24 15:53:47] |
John - SC Support - Posts: 31334 |
Follow through the Setup Instructions to connect to Interactive Brokers here: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-25 03:55:45] |
Hi, yes i saw it but my question is which language do i have to use? is it c++ ? is it pyhton? the code has to be on sierra charts or on IB? remember, i want to execute in IB depend on indicator that is on sierra charts platform. Best regards, amit |
[2020-03-25 04:13:04] |
There is no language involved with the study we linked to in post #2. If you want to use ACSIL, then it is C++. The custom trading study you develop will be within Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-25 04:13:15
[2020-03-25 12:12:09] |
Hi, thanks for your answer so just to make sure: all the condition is in sierra charts and if i do it right the trade will be execute in interactive brokers? regards, amit |
[2020-03-25 19:47:38] |
Yes this is correct.
[2020-03-26 03:42:09] |
Thank you very much for your help. Regards, amit |
