Date/Time: Thu, 02 May 2024 17:56:01 +0000
last SC version that supported Ameritrade data
View Count: 515
[2020-03-23 18:26:10] |
ejtrader - Posts: 688 |
SC Team - Would you please let me know the last version that supported Ameritrade data Connection? PS: I understand it's no longer officially supported any longer - but just wanted to know - which was the last version that was allowing Ameritrade Connection. Date Time Of Last Edit: 2020-03-23 18:27:19
[2020-03-24 01:18:34] |
Version 2021 and earlier definitely do support TD Ameritrade: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2021 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-24 02:13:03] |
Thanks SC Team. FYI - If anyone interested - The last version that works with Ameritrade is 2025. Thanks Date Time Of Last Edit: 2020-03-24 02:13:45
[2020-03-24 04:33:11] |
Ok good.
