Date/Time: Sat, 27 Apr 2024 19:09:50 +0000
TPO SIMPLE (BUT REALLY USEFUL) ADDITIONAL FEATURE
View Count: 976
[2020-03-23 16:20:39] |
lucascastro - Posts: 15 |
Hello, I'm not a programmer so I don't know how difficult would be to add such feature Aa feature that allows the visualization of the "current" (the last one) TPO profile in a duplicated mode. Being the first one not collapsed and the next one collapsed (letter/blocks in own collum). Adding such a feature would give the trader an instant profile shape and letter/blocks movement. I know how sc team is busy but if this is just a simple feature please add it. I have attached a picture to illustrate such a feature. thanks |
[2020-03-29 18:51:09] |
any comments?
[2020-04-15 03:40:10] |
well, I'm using 2 windows but it is not the best setup.
[2020-04-15 22:21:13] |
This is on our list of things to add. We will try to do it soon.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-15 22:21:27
[2020-04-21 11:03:12] |
User968625 - Posts: 256 |
Yes, that’s really a great and hopefully a simple thing to add. Had been requested multiple times over last 2-3 years. Thank you SC Engineers
[2020-04-21 11:33:18] |
We started to have a look at this and it is actually very involved to do.
[2020-05-02 23:58:22] |
Any update on this one, really good feature for all of us who follow TPO theory and Jim Dalton I know you have a big list of things but hope you can do this one |
[2020-09-24 03:08:49] |
Still any interest on implementing this feature? I hope.. Thanks |
[2020-10-25 23:28:08] |
This has now been released. Update to the latest version of Sierra Chart: Software Download: Fast Update If you right-click on a profile, you have the option to display this type of configuration. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-26 07:13:10] |
ticinotrader - Posts: 377 |
Regarding this new feature - would it be possible to add the option to display the Last Trade Arrow at the Own Column as well? Thank you. |
[2020-10-26 10:38:09] |
Sudhirc - Posts: 50 |
that would be nice, second that (Post #10)
[2020-10-26 19:31:35] |
We will check on post #10.
[2020-10-27 12:47:26] |
Thank you for finally doing this. rally great and needed. One thing, can we have an option to always have the own coulmn for the last profile. always for the alst one. thanks
[2020-10-28 03:50:39] |
You have to manually set the last visible profile to display subperiods in their own column. And then make changes to this as new profiles are added.
