Date/Time: Sun, 05 May 2024 02:54:06 +0000
data bitmex
View Count: 492
[2020-03-23 16:07:02] |
User719206 - Posts: 92 |
Hello , when i use historical market depht data or depht market bar , there is only the data since i opened SC, Is there a way to get the previous data ? THANKS FPR YOUR HELP :)
[2020-03-23 18:17:52] |
Not at this time.
[2020-03-25 14:40:03] |
a SC exchange feet data for bitmex gonna be available one day in SC ??? Is possible to import my own data to open a chart with the deph market data ? ( or only high low open and close ) . Thanks for your answer ( I already wrote this message 2 times before and it desapear ) |
[2020-03-25 18:51:52] |
The BitMex data feed is supported. Refer to: Cryptocurrency / Bitcoin Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
