Date/Time: Sat, 27 Apr 2024 11:59:38 +0000
1980S OIL DATA
View Count: 919
[2020-03-23 15:32:47] |
tdug - Posts: 124 |
Hi, I am trading CL NYMEX Futures. I get my data from SC. I would like to load detailed Tick data for CL from the 1980s. Further back if possible. I have used historical charts but not able to load anything of detail below 1999. Is there an additional data pack I need? Help would be appreciated and I am willing to pay for a live phone support ticket on this. Best Tim |
[2020-03-23 18:06:15] |
Intraday data is not available that far back in time. You have to find another source for this. And then you can import it: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-23 19:47:50] |
tdug - Posts: 124 |
Any suggestions on where I would get that to then import it?
[2020-03-23 22:26:57] |
See if they have it here: https://www.tickdata.com/ If you have any difficulties with importing the data, just let us know and we can add support for whatever format they use as long as it is in a text format. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-23 22:27:24
