Date/Time: Wed, 08 May 2024 16:00:37 +0000
Keyboard Shortcuts
View Count: 516
[2020-03-22 10:30:17] |
User831216 - Posts: 2 |
Hi, I set a trading keyboard shortcut for "Flatten and Cancel" even confirmed by "Assign" an "OK" (see attached screen shot with "ALT" + "X"). Nevertheless it doesn't work. What's going wrong? Did I miss something? Thank you for your support. Kind regards, Alex Date Time Of Last Edit: 2020-03-22 11:08:36
Screenshot_1.png / V - Attached On 2020-03-22 10:24:34 UTC - Size: 25.34 KB - 220 views |
[2020-03-23 09:55:32] |
Refer to the documentation here: Basic Trading and the Trade Window If keyboard shortcuts are not enabled for the chart there is an error message given in the Window >> Message Log when using one . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-23 09:55:41
