Date/Time: Tue, 07 May 2024 00:54:38 +0000
How many incoming sierrachart connections should be coming through the firewall?
View Count: 497
[2020-03-21 18:44:34] |
User863099 - Posts: 8 |
I have included screen shot of 6 sierrachart connections coming through my firewall. I am wondering if they are all necessary? I have changed some of them to secure connection and two of them will not let me change to secure connection. Just wondering if this is normal?
Private File |
[2020-03-21 22:46:38] |
There should be no incoming connections at all and at most there would be one UDP connection. But there certainly will be multiple outbound TCP/IP connections. Whatever you see is required. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-22 21:59:29] |
In my windows Defender profile I only have options for sierra chart having inbound connections. There is no name for any outbound Sierra chart connections.
