Date/Time: Sat, 27 Apr 2024 18:50:43 +0000
ReduceOnly for Stop Attached Orders doesn't work on Bitmex
View Count: 452
[2020-03-21 17:39:15] |
dmnk - Posts: 6 |
Hi, ReduceOnly for Stop Attached Orders on Bitmex doesn't seem to work correctly. Example scenario - long position with 10 contracts and two attached stops for 10 contracts each - first stop is hit and the position is closed, the second stop opens a new short for 10 contracts. Please investigate. As a workaround, a "Close" additional 'execInst' for Stop Orders can be set but then if I want to set the Stop to open a position I need to remember to change the DTS setting. |
[2020-03-21 23:40:39] |
Check with BitMex on this. The "ReducedOnly" instruction is added to those Stop Attached Orders if you enabled SpecifyReduceOnlyForStopAttachedOrder
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-21 23:40:55
