Date/Time: Mon, 29 Apr 2024 12:03:16 +0000
"Use Date Range" loads beyond "To" date
View Count: 757
[2020-03-20 22:27:59] |
User119315 - Posts: 11 |
I am attempting to load a portion of an intraday continuous futures contract (ES) (2010-2013) to cut back on load time as I switch between chart bar periods, however the software is loading all data from the start date I input to the present (The small loading percentage window goes all the way into 2020 contracts). When the loading process is finished the chart is correctly displayed with only the date range I inputted, but the purpose of speeding up load time is defeated by the loading unnecessary data from the file. Is this a bug? Perhaps I am doing something wrong, but this seems to be incorrect behavior judging by the documentation: "The From and To settings specify the First and Last dates of data to load into the chart from the data file. ....... These settings are useful to look at days in an Intraday chart data file that go back a significant amount of time, without having to load all the data up to the current Date." Thanks in advance |
[2020-03-22 02:36:17] |
We will check on this, attach an image of the Chart Settings window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-22 02:37:51
[2020-03-22 02:45:42] |
No need to provide any image. We will resolve this.
[2020-07-02 00:31:06] |
This issue has returned. It was fixed in the release that followed the original exchange, but the incorrect behavior is back. Not sure when it began acting up again as I have not used the feature in a while. Glad to provide screenshots or files if needed. Thanks in advance.
[2020-07-03 08:44:41] |
The basic problem is when we solved this we created another problem and then we get another problem report about that and then after we solved that, this problem comes back. And honestly we forgot what the other problem was precisely. We really have to request that you change the symbol of the chart to match with the last date loaded. Do not use a future dated symbol relative to the last date to load. So you have the ability to solve this. We cannot go back and forth on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-07 23:53:56
