Date/Time: Mon, 06 May 2024 00:58:21 +0000
Edit>>Delete All Data And Download with second (destination) instance of SC
View Count: 1005
[2014-01-10 13:03:19] |
User16114 - Posts: 153 |
when doing Edit>>Delete All Data And Download to refresh data in the destination instance of SC getting the following message... "This is a remote chart data file. Perform... where data file originates from." How can I refresh data in the 2nd (destination) instance of SC when I do not have a chart opened in the first (remote) instance of SC? |
[2014-01-10 17:46:28] |
You cannot. This is what the message is telling you. You need to go to the source instance and open the chart and re-download the data from there.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-10 17:46:38
