Date/Time: Sun, 04 Oct 2026 16:25:59 +0000
new instance data connect
View Count: 781
[2020-03-20 10:15:11]
User916807 - Posts: 12
hi,
I opened a new instance to do sim trading , so I can continue live trading on main instance.
In the new instance , the charts don't load
http://www.sierrachart.com/image.php?Image=1584699215672.png
Is there a way to solve this?
thanks
[2020-03-20 18:13:00]
First we want you to wait a few minutes for the data to be downloaded in the new instance. If there still is a problem, then select File >> Disconnect in the sub instance. Close the Chartbook and just open one chart for the symbol of that chart, and do not set it to a continuous futures contract chart, and see if the chart data downloading completes in the chart loads.
