Date/Time: Mon, 06 May 2024 06:30:24 +0000
Using Rithmic data with RTrader through Earn 2 Trade
View Count: 1033
[2020-03-19 20:41:40] |
User443772 - Posts: 10 |
I'm expecting that SC will work with Earn 2 Trade's Rithmic data, however the server they specify does not show up in the SC select-able options. I want the "Rithmic Paper Trading-Chicago Area" I should also note that I have not received an activation notice. I have been using SC through Infinity Future/ACT; will my chartbooks work with the SC software downloaded directly? |
[2020-03-19 22:23:02] |
We have discontinued technical support for Rithmic so consider Earn 2 Trade unsupported at this point in time. Will my chartbooks work with the SC software downloaded directly? Yes. Refer to help topic 15 for instructions to copy them to the new installation :Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-19 22:23:31
