Date/Time: Tue, 07 May 2024 10:54:11 +0000
Time Alert
View Count: 1214
[2014-01-10 12:17:53] |
moonmist - Posts: 127 |
Hi, After opening the Alerts Manager, I see the tab "Time Alerts", and then the button "Add Time Alert". Is it possible to use this feature to remind me of important news ? For example, the US monthly job report will be released at 8:30 AM Eastern Time today. Can I set up an alert that will be triggered at 8:25 AM ? Thanks. |
[2014-01-11 01:56:25] |
Yes. You can set any Time Alert that you require.
[2014-01-27 12:07:33] |
Hi, I have been using the "Time Alerts" feature for two weeks. So far, so good. I do have one question: Is it possible to clear all the old ( triggered ) time alerts in one shot ? For the time being, I have been deleting them one by one. Thanks. Date Time Of Last Edit: 2014-01-27 12:12:53
[2014-01-29 07:29:49] |
No. They have to be deleted one by one.
