Date/Time: Fri, 03 May 2024 06:30:38 +0000
Crosshair not worksg in Chart Values window
View Count: 769
[2020-03-19 15:40:54] |
bodzhar - Posts: 11 |
Hello, Today my chart values window will not show data for the selected bar with the crosshair/chart values tool. The window only displays data for last displayed column. The only difference between today and yesterday is I went from a multi display to single monitor. The X and Y axis of the crosshairs still displays the price and time and date on the chart fine. I've tried numerous chartbooks and even created a new one but nothing has worked in fixing the issue I upgraded SC to the latest version. That did not fix the problem either. Any ideas? Date Time Of Last Edit: 2020-03-19 15:55:59
[2020-03-19 17:18:02] |
The only thing we can think that is happening is that you have the Chart Values Window displayed rather than the Tool Values Window. You can access both of these through the Window menu. If you are still having problems then also display the Compact Tool Values Window and let us know if that is updating properly. Then take a screenshot including those windows and attach it to this thread. Refer to the information here for how to take a screenshot and attach it: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-19 17:18:35
