Date/Time: Sat, 04 May 2024 04:23:10 +0000
Chartbook groups
View Count: 900
[2020-03-19 15:13:20] |
anouar6869 - Posts: 13 |
Hi, Two Questions. 1_Can I use Soft Link in Chartbook Groups folders, instead of putting the real .cht files? 2_There is a way to close a Chartbook Group? For example I open 3 Chartbook Groups and then I would like to close only one of them. The only way that I'm aware of is to use Close All Chartbooks in the file menu. thanks |
[2020-03-19 17:03:28] |
1. Seems like this will be fine. If it works then that will be fine. 2. There is no way to close a Chartbook group in one operation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-19 17:03:40
