Date/Time: Wed, 08 May 2024 21:28:52 +0000
auto re-center stopped for trading DOM
View Count: 1179
[2020-03-19 11:54:48] |
FLfutures - Posts: 11 |
Can neither re-center, and visible price bars are NOT close to last price; unable to page/scroll down to last price. Only use Sierra trading DOM for MES futures.
[2020-03-19 17:04:28] |
First thing to do is to Reset the scales. Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale If this does not solve it, then please attach a screen shot so we can get a better understanding of what the problem may be. Follow these instructions for a screenshot: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage You mention price bars but then you say that you are only using a trading DOM. We are not understanding how you would see price bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-19 17:05:03
[2020-03-19 17:17:05] |
Maybe I was not clear. --No problem with chart itself; --The issue is with the trading DOM, which I only use for MES futures contract. Until today, not only did the trading DOM center automatically, but if I clicked in middle, it would also re-center. I should have mentioned I use IB, as I notice Sierra seems to have some routing issues with IB, although I have not had a problem in the probably 10 years I've used that combination. Sorry, not worth my effort to take a screen shot, but just picture a trading DOM, with prices from several hours earlier; not updating; not centering. I can keep Sierra charts (currently use a computer with 9 LED screens,) & use IB Book Trader (= Sierra trading DOM, but still works properly.) Hopefully you could figure how what changed today with Sierra DOM. Thanks. |
