Date/Time: Mon, 29 Apr 2024 07:23:26 +0000
Denali + SCFeed on same system with same account ?
View Count: 478
[2020-03-19 10:29:51] |
User818063 - Posts: 15 |
Can I use, on the SAME SYSTEM, and with the SAME USER ACCOUNT, 1 instance of SC with SC data feed, and 1 instance with Denali Feed ? If the answer is yes, how to set it up on the Sierra software ? Both SC data feed and Denali setting documentation says to use "SC Data All services". How to be sure I am using SCFeed on instance 1, and Denali on instance 2 ?... Thx. |
[2020-03-19 23:18:54] |
Well the question really is about what symbols are being used in each instance of Sierra Chart. You can use CME symbols in two instances, and other symbols only in a single instance. When using the Denali Data Feed, the CME Group symbols will always come from that feed. There is no further degree of control. And for new users we are no longer offering the CME Group of exchanges through the Sierra Chart Exchange Data Feed. However, aside from all of this, you can share data among instances of Sierra Chart on the same system using a single connection: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-19 23:21:37
