Date/Time: Thu, 02 May 2024 22:11:46 +0000
Daily % change incorrect in chart header
View Count: 427
[2020-03-19 01:44:32] |
User488241 - Posts: 18 |
Hello, I am having an issue with the daily change % not matching up on my chart header. I have attached a picture with chart header circled as well as a reference on my twitter feed showing the market being down 7%. I do need this to reflect accurately for market halt levels. I was not able to find any options to adjust time settings etc for daily change%. Thank you, Daniel |
Daily change % question.JPG / V - Attached On 2020-03-19 01:42:11 UTC - Size: 1.07 MB - 206 views |
[2020-03-19 03:29:32] |
For information about how that field is calculated, refer to: Getting Quotes: Field Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
