Date/Time: Tue, 07 May 2024 09:29:55 +0000
US TVIX
View Count: 407
[2020-03-18 04:11:17] |
Laurunrun - Posts: 11 |
dear sir/ madam, I have got problem whenever I loaded the data of TVIX, the program will be hanged and need to shut down. pls advise me how to solve it. |
[2020-03-18 05:24:43] |
Do you have any studies on that chart? Remove them. You probably are using the Volume by Price study. You will need to increase the Tick Size in the Chart >> Chart Settings for the chart to 1.
