Date/Time: Tue, 07 May 2024 12:58:06 +0000
wierd Daily data
View Count: 485
[2020-03-18 02:15:02] |
Kinobe - Posts: 86 |
hi today for few stocks (not all), I ve got wierd daily data - see attached pictures. I did Delete and download data but i ve got the same result. it is concerned only daily data historical chart. |
[2020-03-18 03:07:31] |
We will tell Barchart about this, and we are publicly saying the relationship with Barchart is coming to an end. We have had enough of enough of enough of the problems. It is nothing more than an embarrassment for us, and it is coming to an end for good. As soon we can. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-18 11:18:56] |
This is now resolved. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
