Date/Time: Mon, 29 Apr 2024 01:43:13 +0000
Chartbook
View Count: 441
[2020-03-17 21:31:47] |
User161549 - Posts: 81 |
My main current PC is not working at the moment and is estimated to be down for a week, I have another PC i can use but dont have my current chartbook that my main PC has with all my custom settings and layouts Is there anyway possible to access those chartbooks without having access to that main PC ? Thanks for your time |
[2020-03-18 06:55:10] |
No. You need to be able to get to the files on that other computer.
