Date/Time: Tue, 07 May 2024 22:30:30 +0000
Difference between renko bars live and in hindsight
View Count: 674
[2020-03-17 13:58:36] |
User719310 - Posts: 23 |
Hi attached is GCEJ20 36 renko bars drawn live and one in hindsight. The lows at 10:57 have different bars in each, can you make them consistent as this affects back-tests. Thanks http://www.sierrachart.com/image.php?Image=1584453444778.png http://www.sierrachart.com/image.php?Image=1584453395834.png |
[2020-03-17 19:11:51] |
Did you re-download the historical data in the chart which then caused the difference?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-17 19:12:03
[2020-03-17 20:38:35] |
I duplicated the chart, nothing else, I was going to make changes to the new chart when I noticed the difference.
[2020-03-17 20:54:01] |
It does make sense that there would potentially be a difference in that particular case. And the reason for the difference would be a different starting Date-Time in the chart. You can look by going to the very beginning of the chart.
[2020-03-17 23:09:49] |
Yes the starting Date-time of the charts are different but it is a duplicated chart both with the setting 5 days to load. When I duplicate a chart is doesn't duplicate the same starting Date time I have tried with some others, is it possible to make it do this? |
[2020-03-18 11:18:18] |
One chart actually had more than 5 days loaded in it. As the days go by a chart will load more data than the setting. To avoid the effect of this, enable this option: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-18 11:18:29
