Date/Time: Fri, 03 May 2024 20:20:37 +0000
DOM Column showing Difference between Traded Bid Volume and Traded Ask Volume
View Count: 560
[2020-03-17 07:56:48] |
User471548 - Posts: 24 |
Hi, How can I have a column in the DOM showing the cumulative difference between Traded Bid Volume and Traded Ask Volume for the session at each price, and also displaying Cumulative Last Size in this column? Thanks. With warmest regards, Mike |
[2020-03-18 07:02:07] |
Have a look at the Volume by Price study: Volume By Price Study It does have a volume bar calculation method for the difference between Ask Volume and Bid Volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
