Date/Time: Sun, 04 Oct 2026 16:28:20 +0000
Data Feed Connection Issue with SC Futures Order Routing/Data
View Count: 1219
[2020-03-17 02:21:15]
User139520 - Posts: 28
I am a customer of AMP. I want to connect to SC Futures Order Routing/Data. I am not able to do so successfully although I follow all the steps provided in this link: Sierra Chart / Trading Technologies Futures Order Routing Service
Please help me troubleshoot the connection issue. Below is the message log in case you needed it. Thank you for your assistance!
Reading Internal Order ID file. | 2020-03-16 20:37:06.370
Reading Trade Orders file. | 2020-03-16 20:37:06.450
Reading Trade Positions file. | 2020-03-16 20:37:06.451
Reading Account Balance file. | 2020-03-16 20:37:06.451
UDPListener (1016). Port 22904 | Listening on UDP port 22904. | 2020-03-16 20:37:06.468
Software version: 2065 64-bit | 2020-03-16 20:37:06.468
Safe Mode enabled | 2020-03-16 20:37:06.468
Enabled for: Sierra Chart Historical Data Service. | 2020-03-16 20:37:06.468
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-03-16 20:37:06.468
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-03-16 20:37:06.468
Enabled for exchange2: CME | 2020-03-16 20:37:06.468
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-03-16 20:37:06.468
Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-03-16 20:37:06.468
Custom symbol settings values: enabled | 2020-03-16 20:37:06.468
Chart Update Interval: 500 | 2020-03-16 20:37:06.468
Intraday Data Storage Time Unit: 0 | 2020-03-16 20:37:06.468
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-03-16 20:37:06.468
2020-03-16 20:37:06 Local computer time | 2020-03-16 20:37:06.469
2020-03-17 01:37:06 Local computer time in UTC | 2020-03-16 20:37:06.469
2020-03-16 20:37:06 Local computer time in SC Time Zone | 2020-03-16 20:37:06.469
2020-03-17 01:37:06 Server time in UTC | 2020-03-16 20:37:06.469
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-03-16 20:37:06.469
Program path: C:\SierraChart\ | 2020-03-16 20:37:06.469
Data Files path: C:\SierraChart\Data\ | 2020-03-16 20:37:06.469
OS Version Number: 6.3 | 2020-03-16 20:37:06.469
Locale Setting: C | 2020-03-16 20:37:06.469
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2020-03-16 20:37:06.483
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-03-16 20:37:06.507
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-03-16 20:37:06.627
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-03-16 20:37:06.627
Received 5 login tokens. | 2020-03-16 20:37:06.936
Symbol settings MD5 received. Request ID: 1. | 2020-03-16 20:37:07.124
Symbol settings are up-to-date for sc_futures.dtc.trading. | 2020-03-16 20:37:07.124
SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-03-16 20:37:12.083
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2020-03-16 20:37:12.084
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-03-16 20:37:12.085
SC Futures Order Routing/Data | Connected to server. | 2020-03-16 20:37:12.140
SC Futures Order Routing/Data | Starting socket receive thread. | 2020-03-16 20:37:12.140
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2020-03-16 20:37:12.140
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2020-03-16 20:37:12.295
SC Futures Order Routing/Data | Sending logon request message. | 2020-03-16 20:37:12.295
SC Futures Order Routing/Data | Received logon response. | 2020-03-16 20:37:12.343
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2020-03-16 20:37:12.343
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2020-03-16 20:37:12.343
SC Futures Order Routing/Data | Connection error: Trade account not assigned. | 2020-03-16 20:37:12.343 *
DTC Client socket (1) | CloseSocket call. | 2020-03-16 20:37:12.381
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-03-16 20:37:12.381
SC Futures Order Routing/Data | Disconnected. | 2020-03-16 20:37:12.381
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-03-16 20:37:12.434
DTC Client socket (1) | Closed. | 2020-03-16 20:37:12.434
[2020-03-17 03:14:03]
The trading account has not yet been assigned to your Sierra Chart account. We will check on this.
[2020-03-18 00:59:15]
Good evening,
Just following up on my ticket, has the trading account been assigned to me yet? How do I connect to the live data?
Regards,
[2020-03-18 05:33:09]
We apologize, that this was not followed up on our side until now. It appears as though that AMP never contacted us about this but we can see they did do the TT account set up. So we have assigned it to your Sierra Chart account. You are all set now.
