Date/Time: Sun, 19 May 2024 00:28:33 +0000
Attaching Trade Window
View Count: 594
[2020-03-16 15:30:22] |
User993067 - Posts: 145 |
I see that the trade window can be attached to either the left or right side of DOM...can it also be attached to the top or bottom of a chart or DOM?...like a control bar...displayed horizontally instead of vertically...when its on left or right side it robs me of screen space, and floating it so far is a distraction and covers data...
[2020-03-16 18:44:58] |
This is not supported for the Trade Window, but you can customize a Control Bar button to have most of the same functionality as the Trade Window and then have that be horizontal. Refer to the following: Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
