Date/Time: Sat, 18 May 2024 18:26:17 +0000
upgraded to 2065: lost control bar icons
View Count: 525
[2020-03-13 08:06:42] |
ycomp - Posts: 277 |
I upgraded to 2065 and all my icons (default sierra icons) on my control bars disappear, it's only text. How do I get them back? |
[2020-03-13 08:21:46] |
The text is much better because it is clear and scalable. But you can still use the old images. Refer to the instructions here: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-13 09:10:44] |
I would have to update every button individually?
