Date/Time: Wed, 15 May 2024 07:48:05 +0000
Zig Zag Study
View Count: 526
[2020-03-12 18:25:41] |
markuz - Posts: 90 |
from client: I have noticed a glitch regarding hiding the Zig Zag study in Sierra Chart from the Region Data Line (please see the first attached image). When you right click on the Region Data Line you get a drop down menu in which there is an entry called "Hide". Under Hide there are all the studies on the chart. If I want to hide the Zig Zag study, only the zig zag line will be hidden and all the inputs will remain visible on the chart (please see the second attached image). If I hide the Zig Zag study from the Study Settings window (please see the third attached image) using the check box "Hide Study" on the left, the Zig Zag study will be hidden entirely, which is what I want. It would be nice to be able to hide the Zig Zag study from the Region Data Line because it's a faster action. Please let me know what you think. |
Zig Zag 1.png / V - Attached On 2020-03-12 18:25:21 UTC - Size: 66.12 KB - 252 views Zig Zag 2.png / V - Attached On 2020-03-12 18:25:26 UTC - Size: 112.7 KB - 263 views Zig Zag 3.png / V - Attached On 2020-03-12 18:25:32 UTC - Size: 93.11 KB - 212 views |
[2020-03-12 18:33:58] |
Yes this is true. There really is not a solution to this in order to maintain efficiency with hiding a study through that shortcut menu.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-12 18:34:03
