Date/Time: Thu, 16 May 2024 10:26:24 +0000
DOM issue
View Count: 481
[2020-03-12 15:11:43] |
User392279 - Posts: 67 |
Stack shows more than 100 orders added but limit order only shows 1 http://www.sierrachart.com/image.php?Image=1584003392725.png |
[2020-03-12 18:31:34] |
We are not sure exactly what you are referring to. Can you be more specific. And point out in the chart image, specifically what you are referring to.
[2020-03-13 04:24:09] |
Limited order size should be always larger than stacking number. I was refering stack number 139 but the limit order only shows 1.
