Date/Time: Sat, 18 May 2024 18:47:07 +0000
Problem with "Trading: position average price" indicator
View Count: 519
[2020-03-12 14:31:15] |
User917679 - Posts: 76 |
I noticed that this indicator will sometimes fail to register a fill when trading is NOT executed at the beginning of the bar period.. I'm wondering if there's a way to get this indicator to consistently and precisely execute, or if there's something that can do the job better... Date Time Of Last Edit: 2020-03-12 17:47:54
offtime.png / V - Attached On 2020-03-12 14:26:37 UTC - Size: 17.94 KB - 164 views |
[2020-03-12 18:59:12] |
Make sure your computer's clock is set accurately: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Also update Sierra Chart to the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-12 20:31:25] |
Alright I re-synced my clock(although I think it was just about accurate already), What's strange here also is that this delay occured during a live-sim front test; If I used the accurate backtest replay mode it seems to fill fine... |
